Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does the card length listed in product descriptions count the front part of the bracket or just the card itself? I have 11.5" in my case and this 6950 I am looking at is 11.3" so just making sure.
good youtube video you can check it on. the 6950 and 6970 use the same PCB, so theyre exactly the same lenght. its about 10.75" without the bracket, and the connectors are on top, so you should have about .75" extra, no sweat!
