I would look into LSI SAS/SATA cards. Here is an 8 port card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16816117157&Tpk=SASUC8I
It uses multilane connectors. Each one has four lanes, so eight ports total without the use of expanders.Isn't that only a two port card for an 8x pci express slot or am I missing something?
I believe the HIghPoint cards are more reasonable in price and come with cables.
That one is actually a regular card and not one of Supermicro's proprietary UIO cards.Currently they are not cheaper at newegg (that I can find) but I guess you can find some elsewhere.
There is also the SuperMicro AOC card
http://www.newegg.com/Product/Product.aspx?Item=N82E16816101358
This is supposed to work on a special port that comes in some supermicro boards. Luckily this is really a PCIe port but the board is backwards (on the opposite side) so the bracket will not work in a PCIe slot without modification.
Almost every other Supermicro card is proprietary like they mentioned.I don't know where this info came from
This is regular PCIe x4 card and it works perfectly without any modifications. It comes with both low and regular bracket. I don't see why somebody would pay $150 when this card exatcly the same.........
