Card Dead?
p0lish
I have a 9800 pro that seems to be dying on me. The screen messes up and it does it randomly, and if you restart it goes away for awhile. I also have a PCI vid card that is fine regardless of what the other one is doing. This system is an Intel Shuttle box that is water cooled, and not overclocked until i figure this thing out. Using MBM5, my +5 is 4.91, core is 1.52, 3.3 is 3.31, +12 is 12.6, -12 is -12.7, and -5 is 0.67? Im not sure if its the power supply or the vid card or what. This sucks. I included a pic to show what its doing.
p.s. The third isnt messed up, because its on the second vid card.
hummmm
could be an unstable powersupply.
or the card could be going.
heres what i would do.
1st underclock the card to reduce heat. see if this helps.
2nd reformat and fresh install of drivers.
if this doesnt help.
try another powersupply.
but since you put in another card it could be the card just dying. although i suspect its a heat issue.
maybe you have a processor or something hot by it???
I had a similar problem and replace the thermal with AS5 and it's running great for couple of weeks now.
