Fenris_Ulf said:Theoretically quite possible and easy. But it will pull a few amps off the 12v rail and produce some heat. If you're just looking for an easy integrated amplifier that runs off 12v, there are better choices.
The magnets from any decent sized car stereo would wreak HAVOC on your system if too close. I have seen car subs hooked up before though.
where do you think the most powerful magnets in your home already are, there inside your hard drive. other then a floppy there aren't really any magnetic sensitive parts in a computer, besides, look at your case fans, guess what, theres magnets in there!
Sorry for digging up an old thread but I successfully jumped my ATX power supply with a piece of wire and hooked my car stereo up to it.![]()
The only wires on the head unit you need to use are the 12V constant, accessory wire, and ground.
