My CarPC is undergoing its trial stages. I know all the parts that I want to invest in, so its pretty much all etched into stone.
The only worry I have is cooling systems. The plan was to buy a fan controller, and modify it into the dashboard under the AC controls, but I have a few concerns.
I know that the 4 fans on the controller will do a decent job of cooling, but the hot jersey summers are beginning to worry me. My first though was to have the PC in the glove box, but that i realized that was too small. THEN I decided under the seat/in the trunk. The seat would provide minimum airflow while the trunk will supply the maximum airflow (even though running cables will be a bitch).
So heres the break down.
Under the seat:
Minimal airflow, 4 - 6 fans, possibility of overheating.
In the trunk:
Maximum airflow, 4-6 fans, more ability to cushion PC form bumps. Terrible time wiring.
Passenger foot space:
If I put the PC in the foot space for the passenger seat, id loose about 6-8 inches of foot space, but I will be able to re-rout the AC unit to the box, and get cooling from there too.
Now I'm not sure if I should've posted this in Cooling or PC mods, but I assume a mod will correct me and put the dunce hat on me if I'm wrong.
Under the seat:
In the trunk:
