King Icewind
- Jan 17, 2008
I tried searching and I didn't find much.
I have a 4+ year old Corsair TX850. I want to get a second R9 290. I read that,
Am I really down approximately 170+ watts at 20%? I did run two 5850s for 3ish years.
Specs of my computer:
Intel Xeon L5639 @ 3.2ghz (is a 60W TDP processor at stock speeds)
12GB of RAM (6x2)
2 hard drives, and 1 SSD
4 x 120mm fans
1 watercooling pump
1 R9 290 + want to add 1 more
Am i okay to run this for awhile? Otherwise I was going to get a Seasonic power supply around 1000watts.
Thanks.
When used heavily or over an extended period of time (1+ years) a power supply will slowly lose some of its initial wattage capacity. We recommend you add 10-20% if you plan to keep your PSU for more than 1 year, or 20-30% for 24/7 usage and 1+ years
12GB of RAM (6x2)
4 x 120mm fans
1 watercooling pump
Thanks.
