quite a story so as breif as possible...
had xp: home installed. also had norton av 2005 installed. found out norton was hindering many apps, including napster, which, all of a sudden stopped working. at that same time norton gave an error message at every startup that it "didnt support the install feature" and that it had to be reinstalled. norton didnt seem affect by this error, so i just continued on with it, as it was. well, i finally wanted to use napster, so i tried going into safe mode to install napster from there, and see if it would get around the norton installation.
well... i never made it into windows again. i set the computer up to restart in safe mode through msconfig-->boot.ini-->safe mode:minimal. restarted the computer. now the computer restarts just before after it loads the agp driver. tried several times. then i tried booting into windows normally. the computer restarts just before the welcome screen, every time. last know good config does same thing.
so... i reinstalled windows over the top of the last installation. windows loads fine except!.....
i now cant get it to NOT load into safe mode. tried reconfiguring mscong-->boot.ini several times... no go. i couldnt find a boot.ini file in the windows folder. added one. but it wont change it. is that the native folder for it? i cant remember. xp:home edition
any other ideas would be much appreciated also. Thanx
