Can't seem to send PM's
Status
Not open for further replies.
When i click Submit Message, it loads the default Private Messages page (like i assume it should), but shows 0 messages in Inbox and 0 Sent Messages.
I've tried with opera and firefox browsers - all java and plugins enabled.
Only thing i can think of is this account might not be old enough to use PM function maybe?
Thanks very much for any suggestions.
Click here:
http://hardforum.com/profile.php?do=editoptions
Under the Messaging & Notification area put a check mark in the "Save a copy of sent messages in my Sent Items folder by default" box and then hit save changes at the bottom. Your sent messages aren't automatically saved by default unless you check that option.
I just sent a PM to you so you can confirm that you can receive them.
Thanks! That solves that. Sheesh now i should probably send one last PM explaining why i flooded his inbox.
Status
