Cant seem to get ocing right
AliP
Quick specs: E6600+680i+Z9700+Ballistix Rated 1000mhz.
I'd like some info at what voltages should be set at, and i mean all of them, not just the cpu core, have never done this before so i dont know exacly what im doing but i get the basics i guess. Have the limiting options to off (stuff compiled from a few guides) , mem to linked, mem ratio 1:1, set memory to 800 (fsb=1333) (cpu=9x333=3Ghz) and i tweaked the votages a little but i dont think i got it right. When i started up windows the system frose after a few seconds at desktop. Please help, thanks. :confused:
I don't know much about the 680i and how the BIOS is but I can tell you my settings on the 650i (baby bro :cool: )
When I first started I had it @ 3.4ghz but it was unlinked so I didn't have the 1:1 ratio many people talk about...decided to do 1:1 so I can be like everyone else :p
I lowered my multi to 7 so I could get the required 1:1 ratio
Well here are my settings using a E6600 + 650i + Firestix
CPU voltage = 1.37
Memory voltage 2.08
Northbridge voltage 1.739
FSB = 475 (or 1900 as it says in the bios...1900/4 = 475x7 = 3.325)
Memory = 475 (x2) = 950 @ 4 4 4 12 2T
Don't know if that explains anything but those are my settings...what you should so is this
To get 1:1 you need your FSB to be 400 (400x4 = 1600 or 400x9 = 3600)
I don't know if you want to oc to 3.6ghz so lower your multi to 8
Put the FSB to 400 which will get you 3.2ghz (400x8 = 3200)
Memory should be running @ 400x2 = 800 so that's 1:1
Try to do this at the stock voltage (1.325). If it freezes go back and increase the voltage until it's stable
Thanks for the help, im guessing by 1:1 they actually ment sync mode, i was trying to run my memory at 1333 mhz :S anyway i got it stable, for now.... But i need a little more help as soon as possible, here take a look at this:
The mem volt is manually set according to specs, the cpu is set by your reccomended volt, but else is at auto, but its showing up red and giving me a scare, is this all ok? As you can see im running prime, isnt that a good stable testing program? Please Answer asap, before i loose courage and set it back in case im doing something wrong. Thanks! :D
Bump! Cmon Cmon, give me a response before i have a panic attack ;) Additionally, some programs tell me its running at 3600mhz but it is running at 3200?
Bump
Edit: Never mind found out some of those colors were normal and the others were fixed, thanks for the help suge.
Yeah that looks perfect.
So you've got it at 3.2ghz + a 1:1 ratio w/memory running at 800mhz?
Good job!
