Can't seem to get 2nd monitor to turn on
etegv
Hi, guys
I have a strange issue. I added a second monitor to my setup, but that monitor refuses to turn on with the monitor. I can only get one monitor to work at a time. The 2nd monitor goes into HDMI power saving mode when I have both monitors hooked up to the GPU/. I believe the primary monitor uses DVi-D (port on the far right on the 5700 XT)? The 2nd monitor uses HDMI. I am using the 2nd monitor right now with the other monitor unhooked. Anyone know a what the issue might be?
thank you so much
pendragon1
that ^^^ and 5700xt does not have a DVI, it has displayport and hdmi. what happens if you only use the hdmi monitor?
