bigboutros
- Aug 26, 2004
hello all,
am having problems "save as" to a network drive f: (see below) , thanks for checking out my post.
a friend of mine accesses many files off of a drive f: on a remote win98se system, she is using XP home. There is no problem accessing opening or altering files the problem comes when for instance an edited word (newreport.doc) file is edited and then you attempt to "save as" a new file name (i.e newreport2.doc), back to the f: drive. When you do this the following error/dialog occurs.
"the folder f:newreport2 isn't accessible or the folder may be located on an unavailable volume or protected with a password"
there is no folder i am trying to access or save, it is a Word file? It is like the OS is recognizing or thinking i am trying to access a folder by the name of the document i am trying to save. So it is seeing newreport2.doc as a folder trying to be opened not a document trying to be saved. Any ideas why this would be? or how to fix it?
i would greatly appreciate any info. thanks so much and have a blessed day,
Boutros
ps. There is a round about way to save the file, by copying it from the f: drive, to c:, editing, "save as" and then copy it back to f: but i hope to find another "real" solution. thank you
Boutros
