You either need more voltage, more cooling, or your FSB is just too high. Ram should be fine with a 245ish fsb and 5:4 ratio, puts it right back to spec assuming 3200.
or...it could be possible your CPU just wont do 3.2ghz without either an up in voltage better cooling...or it just wont do it and you need to back off some. which is probably what the problem is...try to back off some and see if itll run prime.
I was also crashing in Prime95 and 3Dmark with my P4 2.6 clocked at 3.2 GHz. I then upped the voltage for everything, Ram @ 2.64 volts, VCore @ 1.7v, I forget the AGP, but it seems to be running fine with a 5:4 divider. It ups the temps a bit, but I am using stock cooling so there's plenty of headroom to spare...
