Making a post because this has happened to not one, but TWO computers that I own and I'm completely baffled.
Basically what has happened to these computers is that they cannot seem to resolve DNS at all through a wired connection, but wireless is fine. Windows troubleshooting indicates that everything seems fine, it just can't get a response from the DNS server. I run ESET Smart Security on both machines, and uninstalling it actually does not fix the issue, as well as reinstalling network drivers, so I'm starting to pin it down to a Windows specific bug. Allowing the DNS address to be assigned or assigning it myself to Google or whatnot does not fix the issue. I run a myriad of programs unfortunately and it's going to be very difficult pinning it down to a specific executable that is causing the issue, at least to my limited knowledge, and I was wondering if anyone else had experienced a similar issue and would be able to share what caused it?
I can work around it with a stupid, weird fix of adding a USB NIC, which somehow, for some unknown alien reason, doesn't suffer from the DNS issue over time on both these systems.
