I have an FN45 motherboard that came with the SN45G Shuttle XPC. The entire computer was setup and working fine with a Barton 2500+ and 2x512 Geil 2700 rated at 5-2-2-2. Then, I decided to see if I could get my memory to run at 400Mhz. The first time I tried to overclock letting the motherboard control all the memory timings, it didn't POST, but reset itself after about 10secs. I changed the timings to be 10-5-5-3.0, but ever since I made that one change, I cannot get the machine to POST. This has happened to me before when overclocking, so I went to reset the CMOS. The jumper...must be for show. I've done it all, remove the external power from the PSU, reset the jumper, remove the ATX power connector from the board, reset the jumper, remove ATX power connector and external power, reset the jumper, remove no power, reset the jumper. I've even taken the CMOS battery out of the computer for about an hour and a half. I've tried another CPU, different memory, and still can't get it to POST. I e-mailed Shuttle's tech support, but unless they tell me something special about this board that I'm completely unaware of, I'd think something must be wrong with the board itself and RMA it.
The very first thing I changed was setting the CPU and DIMM voltages to 1.75 and 2.7 respectively, and the machine booted into Windows fine. The one thing I did that seemed to make the machine not POST is manually setting the memory timings.
