Cant register@ Hard Folding
Wicked_Bass
Everytime I try to register its says passwords dont match even if i leave them blank!
Any suggestions?
I have the same problem as I try to reregister on the site, since the site has been down long I must have forgotten the password.
Any suggestions?
Same thing here. King_N does mine exist and can we log in? I registered under Buckshot but i show up as guest when trying to log on:(
Thanks!
Buck
Ok, just tried registering a dummy account, everything *seems* to be working flawlessly.
I checked the database and neither you Scorp or Buck have an account, if you registered it must have been before the site went down, some of the records were lost when restoring the database.
Everyone that registered before the site went down, please take the time to check to see if your name is listed in the member area under the correct country/state, if it is not listed then your account was lost and you must re-register.
Other then that I'm at a loss to why it would work for some people and not others, there have been over 40 members that have registered since the site returned.
King_N
Webmaster www.hardfolding.com
Lurker Extraordinaire
i just tried to register and recieved the error passwords dont match again :eek: not sure Y it wont allow me to register :( would like to tho.
EDIT: firefox was the issue used IE and it worked fine. might want to check into that King_N. thanks for the investigation also.
Buck
Not sure what the problem is, just tried registering with Firefox and didn't have any problems, might be your security settings in firefox blocking the info( just a guess).
I will continue to see if I can track the problem.
King_N
Thanks for the reply i found out that my browser i was using on my mac was the problem!!
Thanks
It sure as shit won't let me register... in IE or Firefox. It's pissing me off. Good work on getting the site back up tho! ;)
NVM! I was being dumb. She works!! Halelujah!!!
King_N
I was registered before the site went down but did not show up in the registration.
So I reregistered this morning and I still can not log in!
Help please! :eek:
Still cant log into the site, no errors just keeps on showing, Welcome Guest
Help please! :confused:
KodiakStar said:
I can log in fine, its you who has the problem ;)
so you first. ;)
Yes I know! I was registered befor the site went down, then when it came back up again I was not listed. So I registered agian. Still no luck. I am shown there but cant log in!
Same problem here. I'm showing on the site as registered, but I can't log in under any of my known passwords. Any chance there was a partial data corruption and people's passwords got roasted?
Ok. The site remembers my login data (maybe it's my browser). Not listed as member. Attempt to re-register. Old password didn't work for verification . Tried different password and verify identical pass. System says "passwords don't match". It remembers me, just not fondly, apparently. Can I be purged from the database? Mayhem33 sounds like a similar situation. I kinda like to see the individual overtake and threat charts. Makes the site unique.
Yup, I was registered before.... no record of me now.... I used to be the lone [H]ardfolder in WV.... now there's none....
Keep on Folding!!
Ok everyone,
I have tried registering and logging in using Internet Explorer, Netscape, Opera, Mozilla, and Firefox. So far none of the above browsers have given me any problems, I'm not sure what the problem is, hard to tell when you can't duplicate the problem.
Considering people have registered daily since the site was brought back online the most I can assume is that it has to do with your browser's security settings.
I'm still working on fixes, it's on my list, I'll triple check the code.
Also those of you that were registered before the site went down, check to see if you have a listing under your country, state/province/region, if you are not listed then you need to reregister.
King_N
Mayhem33 said:
King_N
Help please! :eek:
King_N said:
Ok everyone,
King_N
Thats what I mean, Im listed but cant log in. In IE or Firefox, I also get no errors it just looks like it changes pages and displays the same thing.
Thanks for your help! :D
