I recently had one of the 320GB Seagate 7200.10 drives fail in my RAID 5 Array. After RMA'ing the drive I left the server turned off until the replacement drive arrived today.
I put in the new drive and fired up the server again only to be greeted with the following message when I fire up the HighPoint RAID Management console: "The following arrays can not be used, do you want to delete them?: CORTEX_TERABYTE". Obviously I click "NO" - but now I can't do anything other than look at the disabled array.
Here's what I get when I go to Array Management and click on the array:
Here's what I get when I go click on on the first disk in the array:
The other disks (Channel 3 and Channel 4) report the same information, except their Status is "Normal".
According to the manual, I should expect the Array to be in the status Broken and be able to click on Add Disk and Rebuild from there... Unfortunately those options are grayed out. I can only Unplug or Delete the array.
Help!!
Here's the log file from the console:
Code:
ARRAY INFORMATION
Type: RAID 5
Capacity: 959.93GB
Status: Disabled
Cache Policy: Write Back
Code:
PHYSICAL DEVICE INFORMATION
Model: ST3320620AS
Type: Hard Disk
Revision: 3.AAC
Capacity: 319.98 GB
Total Free: 0.00 GB
Max Free: 0.00 GB
Status: Critical
Transfer Mode: SATA300
Read Ahead: Enabled
Write Cache: Enabled
NCQ: Disabled
Help!!
Code:
14/12/2006 5:46:00 PM Disk 'ST3320620AS' at Controller1-Channel2 failed.
14/12/2006 9:42:55 PM Disk 'ST3320620AS' at Controller1-Channel2 failed.
16/12/2006 6:07:05 PM Disk 'ST3320620AS' at Controller1-Channel2 failed.
16/12/2006 6:07:05 PM Array 'CORTEX_TERABYTE' verifying failed.
18/12/2006 7:44:43 PM Disk 'ST3320620AS' at Controller1-Channel2 failed.
18/12/2006 7:44:43 PM Array 'CORTEX_TERABYTE' rebuilding failed.
