Can't pick between 4 motherboards
Rusky
This is for a gaming PC.
They are all in my price range, does anyone have any comments on any of them?
Actually if you know of any other mobo that has in it what I'm looking for, I'm open to suggestions.
This is a list I used to narrow my newegg search
Audio Channels : 8 Channels - Optional, but would be nice
USB : 4 x USB 2.0 - Could be more, not less
IEEE 1394 : 1 x IEEE 1394a - Could be more, not less
Form Factor : ATX
SATA RAID : 0/1/0+1/5 - I was given a few options on the type of SATA, all I care is being able to have Raid 0
Max LAN Speed : 10/100/1000Mbps - 10/100 is a must
Memory Standard : DDR2 800
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
MSI 975X Platinum V.2 LGA 775 Intel 975X ATX Intel Motherboard - Retail
MSI P965 Platinum LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
XFX MB-N680-ILT9 LGA 775 NVIDIA nForce 680i LT SLI ATX Intel Motherboard - Retail
I have experience with the following:
ASUS P5N-E SLI plus (650i)
ASUS P5N32-E SLI (680i)
Both are great boards and in your price range. ASUS has a wierd naming scheme so you have to pay attention.
Both boards I currently use and have been rock solid. Both have SLI set-ups and game very well at high resolution with nicely overclocked C2D processors.
Give them a look see.:D
One of newegg options is confusing me.
Under the SATA RAID, what's the difference between:
and
SATA RAID : 0/1/5/10 Matrix RAID
Different motherboards show up based on my selection. All I want is RAID 0, both of those options support it correct?
Form Factor : ATX
If you aren't ever going to go with SLI I'd grab the MSI P965 Platinum out of those you listed. Even better would be the ASUS Commando which also uses the P965 Express chipset.
SLI is when I have 2 video cards running together?
Then no I won't ever have that setup.
Then I'd get a board based on the i975x or P965 Express chipset. (Preferably the latter.)
If you want a cheaper board based on the 965 Express chipset, I'd recommend the Gigabyte GA-965P-DS3.
I have one of these. Its a great board, single PCI express slot and overclocks like mad.
For just over 100 dollars you wont be sorry.
Agreed.
Like I said, I'm open to motherboards in the 100-200 price range.
The Comando outperform the Gigabyte GA-965P-DS3? And is the price difference worth it?
It doesn't necessarily out perform it. The main thing I can say is that overclocking was super easy with the ASUS Commando. I have no doubt that I could have hit higher overclocks with different ram. (I had killed the test Dominator modules on the previous review.) The main thing is that the Commando has more features than the DS3.
For what it's worth I can throw in my support for the Asus Commando, it does all you'd expect it to do, overclocks real easy and have nice reset buttons that gives a first time overclocker like me a nice feeling of (false) security even if I have never had to use them. :)
My brother has the Gigabyte DS4 mb (DS3 with more features and more copper piping) which is a real nice board also, I still like my Commando better though...
It looks like I'm getting the comando mobo, I'll read a bunch of review before finalizing, but I'm leaning towards it now.
Thanks very much for all the information.
also check out the abit AB9 QuadGT.
imo (& many others) it's a great mobo, does as much or more than the Commando & is cheaper.
I will check it out, thanks
I was talking to a friend and he mentioned that if I get a ATI video card (which I am getting) I should look for a motherboard that has ATI components on it.
How true is this? Should I got out of my way for such a board or will it not really matter?
If its a single card, it should not matter. However the intel 975 boards will do crossfire (ATI's SLI equivelant).
i would go with the msi platinum 650i, its a good board, and if u got any questions theres a big thread about it already, and i like the AB9 Quad GT if you have a little extra money, its more stable and just plain better, and can oc better
It's not. You would have to if you used an AMD processor. If you use an Intel CPU, you should get an Intel chipset to go with it.
not true. dont bother. besides, there are very, very few ati chipset mainboards for intel.
Unless you are going to run SLI, the Intel BadAxe-2 should definitely be on that list.
Form Factor : ATX
The BadAxe is at the top of the price range though, but I've heard it works well. I should have kept the DS3 I had before, I've heard nothing but great reviews from them.
