Can't pick a mobo!
PeteH
I am having a very difficult time picking a motherboard. I don't know enough about them to make a decision. If someone can recommend me an exact motherboard, (perhaps a newegg link or something) that would be greatly appreciated. I wont be using a RAID configuration, and while I plan on getting a 9800gx2 I am using a 24'' monitor at 1920x1200 which some say would be best with SLI while others say the 9800gx2 will handle it just fine. I don't believe I'll be doing any overclocking as well. Thanks in advance.
Processor
Intel Core 2 Quad Processor Q9450 (4x 2.66GHz/12mb L2 Cache/1333FSB)
RAM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit
Power Supply
Corsair Memory CMPSU-750TX 750W TX750W ATX12V Power Supply
Video Card
EVGA 01G-P3-N892-A3 GeForce 9800 GX2 SC 1GB 512-bit GDDR3 PCI Express 2.0 x16
Hard Drive
SAMSUNG Spinpoint F1 HD753LJ 750GB SATA 7200 RPM 32MB Buffer Hard Drive
9800GX2 will do just fine, I am in the same boat as you as far as SLI might help gaming, but to me it's just not worth it. Some good Mobo's are these. Of course I only recommend mobos that are good at oc'ing... just in case you get the urge ;)
