lttletimmy
- Feb 2, 2009
Hey Everyone,
I've been trying my i7 920 overclock, and can't seem to get my computer to even BOOT with anything but the default settings. I first tried to go by the settings used in this guide:
http://www.clunk.org.uk/forums/overclocking/22106-core-i7-overclocking-guide-beginners.html
But had no success, tried lowering the BCLK even more to 140 and it still won't boot. I have a good heat sink and I suspect my RAM may be my bottleneck, but here are my relevant specs:
Core i7 920
Asus P6T Mobo
Xigmatek Dark Knight CPU Heatsink
6x 2 gb G-Skill 1333 mhz http://www.newegg.com/Product/Product.aspx?Item=N82E16820231230
Corsair 750TX PSU
Settings I'm trying to implement:
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto (If you are NOT using a 920, please set this manually to 21)
Intel (R) SpeedStep (TM) Tech - Enabled
Intel (R) Turbo Mode Tech - Enabled
BCLK Frequency - 160
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1282MHz
DRAM CAS# Latency - 8 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 8 DRAM Clock
DRAM RAS# ACT Time - 20 DRAM Clock
CPU Voltage 1.10000v
CPU PLL Voltage - Auto
QPI/DRAM Voltage - Auto
IOH Voltage - Auto
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.60v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
I've tried the DRAM frequency one click lower (962 mhz i think it was), tried the CPU Voltage up to 1.2v, and am afraid to go any higher than 1.6v on the DRAM voltage since my G-skill ram is only rated from 1.5-1.6v.
Sorry if I'm missing something obvious, I'm a little new to overclocking. The computer runs like a champ at default settings but seems to completely break down at anything other than the stock settings. Any advice?
Core i7 920
Asus P6T Mobo
Corsair 750TX PSU
PCIE Fequency - 100
IOH Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
