cant overclock p4pe-x...
Hustle
I have a 2.6 P4(800fsb w/HT). Yesterday I was having temp problems but I reseated the proc and adjusted the Voltage slightly and got past that. Now when I attempt to overclock even the tiniest bit, the system either does not boot up at all, freezes during bootup, or just freezes after a few minutes of use. Does anyone here have the P$PE-x and if so, what did you have to do to overclock it?
I have the regular P4PE and to oc all I do is change the fsb and up the voltage when it becomes unstable. You may want to check your settings for you ram. If they're set too high it would probably cause problems.
