Can't overclock my pc...
VolvoR
On the right is my pc after overclocking...On the left is an image I got off the web...
I have the gear listed below. What am I doing wrong? After about 5 minutes of surfing the web, nothing tough at all, it reboots. What else do I have to do to get this thing up to around 2.5-2.6ghz?
drop the HTL to 4x and and run a 5:6 divider some times its labled as "Max ram speed" and set it to 166 then give it a shot might need more vcore too
I've read the guides, not only here, but other places as well, and it won't go much past stock. I think there's something I may be missing... :mad:
could just be a CPU that dosnt have much in it bad luck :(
i call shens.
have you set your ram divider as mentioned above?
made sure HTT * "FSB" was <= 1000 (or more accuraetly, w/i 10% of 1000)?
i don't think you have.
if you have read the guides, follow them, and then try again.
tell us what your BIOS settings are, not only will that prove/disprove whether or not you've read the guides, it will also let us make more helpful suggestions
good luck.
