Cant overclock K8N Neo2 Platinum
Neo_Cloud_99
This is my brothers system and he lives in another state so I've been trying to help him over the phone with this stuff but we had no luck.
System Specs:
K8N Neo2 Platinum - BIOS 1.3
Winchester 3000+
XP-90 w/92mm Vantec Tornado
2x512 PC3200 OCZ EL Platinum Revision 2
PNY 6800GT
WD SATA 36GB Raptor
Enermax Noisetaker 470W
Ok so I've been doing some research and what I have found so far is that possibly Dimm slots 3&4 work better so his memory is in those slots. Use SATA ports 3&4 so we've done that. He has the 1.3 BIOS. Tried AGP Frequency of 66 and 67 both have same results. At default settings CPU temperature is around 39C in the BIOS. Not sure about PSU rails but I'm assuming they are ok. His system is 100% STABLE at default settings.
We did change the HT frequency to 4x instead of 5. I then had him lower the CPU ratio to 8x instead of 9. Raised Vdimm to 2.85. Left all memory timings to Auto. We tried FSB of 205 it seemed to work ok, 210 ok, 215 ok, 220 Windows starts to lock up during loading and if it does load it locks up or BSOD's before reaching the desktop.
We didnt run any benchmarks or tests with higher than 200 FSB so we arent even sure that was stable. I'm thinking we are missing something... I dont know all the variables because I'm not actually at the machine and from what I've read there are a ton of BIOS options.
Is the 1.3 BIOS not good for overclocking? Are there some BIOS settings we need to change before doing overclocking?
Thanks in advance.
System Specs:
Winchester 3000+
PNY 6800GT
WD SATA 36GB Raptor
Thanks in advance.
Actually with the setting you have now you sreslower then the factory 1.8Ghz clock. I found a very informative forum to have about all you need to know on overclocking A64 stuff. Helped me a ton once you read and understand whats so different with the K8 chips. They arent as easy to crank up as the K7 stuff. All due to the onboard mem controller. Herer are other questions to ask. Like whats the 12V+ rating in amps on that power supply? It might need more powersupply. I had the very same board you are using and with some of the latest bios updates there is some issues with the MSI board auto rounding up with out showing it of course and extending the clock higher then you have the setting. I would expect that with air cooling that Max OC will be no more then 150-200 Mhz. and getting to 2.0Ghz. Im not real familar with the OCZ platinum mem but I do hear that with these Cpu's you want as much extended bandwidth as possible. I hear that the OCZ EB mem is great as well as the Corsair XL is awesome and so is Crucial's Ballistic mem. I would not use auto settings on the memory. You may need to run them at relaxed timings as well. I would also recomend running at 1t if your mem is capable. Just my recomendations anyhow. The link I will give you is a very long post but read though it and filter out the not so needed stuff and you will get a pretty large bountiful amount of info and how to OC the AMD 64 beasts Hope this helps.
Captin Insano
