Cant overclock athlon 64!!!!!!
GMcDougal
i cant seem to overclock my athlon 64 3000 at all. ive dropped the memory to 166 and dropped the HT to 3x and i cant seem to get over 210 stable,and 215 i get crashes in windows and at 220 i get the bsod loading windows. here are my system specs below.
Epox Motherboard http://www.newegg.com/Product/Product.asp?Item=N82E16813123244
1 gig corsair value ram
Maxtor diamondmax 10 SATA
BFG 7800GT
Creative Labs Audigy 2 value
LG CD-Rom/CD-RW
Athlon 64 3000 754 pin (Retail)
Yeah, up the Vcore...also, there's the phrase "You win some, you lose some"
I've run into non-OC'able procs a couple of times...
I was getting crashes in windows and BSODs when passing 230 the problem was my ram timings were too tight. try making the cas and all those number higher.
ive noticed that mb doesnt seem to like corsair very much, with my xms non of the ram dividers would work right an would limit the overclock as soon as i got some 1gb sticks of cruicial value ram the problem went way.
Whats your CPU temps? Idle/Load? If its getting too hot, check ur seating and/or fan.
hmph, i havent had a problem with my board using XMS :confused: im running 290htt
