Cant OC my CPU or video card
qtqc
Hey everyone. Im having some trouble Overclocking my new Asus A8n-SLI with a AMD 3500+. I try OC but it wont boot with anything. I even tried the AI overclock and anything over 5% the computer wont boot again. My cpu temp is always around 39. The other problem Im having is with my BFG 7800 video card. I can OC even 1mhz over stock cause it starts artifacting. When I try Auto detecting the OC it comes back at stock speed. My idle temp is around 53. Im having trouble figuring out the problem. The only thing I can think of is Im running a 20pin power supply instead of the 24 which is recomended. My power supply is a Antec 550w
You need the 24 pin connector. Do you have a 12v molex to the MOBO and a separate power connection to the video card as well?. See http://www.hardwareanalysis.com/content/topic/38623/?o=520
Hey, I have a seperate molex going to the mobo and the power connector to the video card. My pc has run perfect other than when I try to OC. Im probably going to have to pick up a new PSU I guess.
yeah I had the same problem with my A8N sli deluxe, I had to get another PSU, then after that no problems at all
Im glad to see Im not the only one. Guess Im goin PSU shopping for sure.
Hey everyone. I picked up a OCZ 520W PSU and Im still having the same problem. Any idea what it could be?
it could just be ur OCZ 520 that just can't do the job go with an Antec 520 tru power
Umm, don't go buy another PSU. The OCZ is more than up to the task.
Take out all of your ram but 1 stick. Then overclock. You will actually be able to overclock. Then you will see that the A8V does not like more than 2 sticks of ram.
Problem solved, new mobo or 2 sticks of ram.
[/thread]
Starfox said:
...Then you will see that the A8V does not like more than 2 sticks of ram.
He's talking about an A8N-SLI.
To the OP...
Tell us about your ram. What is it's stock speed and how fast are you running it when you overclock.
your motherboard is a pile ( for overclocking ) ..
Bought that board for my computer.. had alot of problems so i sold it at a 30 dollar discount to my friend and it worked for him :(
next time ask the uber l33t 0v3rc10ck3r$ what mobo is pretty good for overclocking
only 2 two come to my mind for agp socket 939
Msi K8n Neo 2 Platinium ( I have this board, it works lol)
Dfi nforce 3 ultra d socket 939 with agp... i hate DFI's way to name boards
Hey this is my setup so far.
A8n-SLI
AMD 3500+
2gb OCZ Platinum PC3200 DDR400
OCZ 520W Sli
My ram is not being OC at all right now
qtqc said:
...My ram is not being OC at all right now
When you increase the CPU Frequency of your processor, you increase the speed of your memory too.
Go into your BIOS and find the setting that says "Memclock index value", set it to 333Mhz then try your overclock again.
Edit: for clarity
I'm running VERY similar hardware and get mild artifacting when I try to overclock my BFG 7800GTX as well. Also the auto detect does set it at the stock speeds per BFG spec. When I dropped my latencies down on my RAM to the 2-3-2-5 @ 2.7v it ran a little wonky and occasionally my games would crash. Not the OS, just the game, so it was definately a RAM issue. Going from 2.6 to 2.7 helped a bit but now I'm running CAS 2.5 so now 2.5-3-2-5 @ 2.7v at 200mhz 1T command rate and it seems to be running better. However with those latencies I too lock up under more than a 5% overclock. With the RAM at the latencies that my mobo autodetects which are something like 3-3-3-5 2.6v @ 333 it can push a 10% OC and run Prime 95 like a champ. Another point of interest is that I've had many hours of good Prime 95 at the 2-3-2-5 it's just games and 3dmark05 that will crash it sometimes.
My main question after all that info is will I get more stability (ie no artifacting) from my video card when overclocking if I raise the PCI-E voltage? I haven't heard much about what all that is good for so any insight would be awesome. Thanx.
