I had posted something similar before but I couldnt find my post.
I have my AMD Barton 2600+ overclocked to 185mhz fsb stable... but if I tried to push further say 195mhz 3Dmark will freeze. I dont think its overheating, because when I overclock I usually crank my fan to high. Is it my memory settings? My memory is PC3200 so it should be able to handle a fsb of 400..
Is it the voltage of my cpu? Its at the stock 1.6v I dont really want to raise that but if it can get me higher then ill be happy.
Oh and anyone here have experience overclocking a DFI nforce2 400 AL? its not that lanparty or that er infinity thing... I have no idea if my cpu is locked becasue it actually doesnt even have a multiplyer setting. I can raise the fsb there though. (currently using clockgen [whats so bad about it? I overclock when I encode or play a gameleave it at default when I dont need as much power])
[/URL]
[/URL]
