Can't OC, any advice
My comp : Asus K8V deluxe revision 1.12, A64 3000, OCZ platinum dual kit 512Mb. After a eclectric shock, my comp can't oc anymore. And my RAM can only plug in DIMM 1-3, 1-2 or 2-3 will result a BSOD. Anybody can help. I guess it because the ram but since i got no budget for a replacement at the moment i wonder if it can be fix.
Try the Memory sticks 1 and 1. in the slot that works and then switch them back and forth in the 2 slots. That way U will work out whether it is the MB or the memory thats Kaputt.
Btw How did U manage to get a shock in the computer? It coud be an insurance question.
