cant lock ram on neo2
ADWulf
i cant seem to be able to lock the ram speed to 200 on my buddy's Neo2 platinum.
i set max speed in the cell menu to 200 but when i change the cpu speed to 220 or so the ram goes up to that high as well.
That's how all motherboards are. Boards that state ram speeds as 200 166 and so on are really comitting a misnomer. Really, those are just ratios. 200 would be 1:1 and so on. On every board you could possibly find the ram speed scales with the fsb/htt speed. The speeds listed in the bios are only for the cpu at stock speeds.
well i was hopin to be able to run at 5/4 divider, so i could possibly run his 3000+ winny at 250 fsb, but i guess no dice?
sure you can. on the neo2, which I have, all you do is set that 'max speed' to 166. that will make the ram a ratio of the cpu's ht speed, so if you run 250mhz, the ram will run at 208mhz, which isnt much of an oc, the ram will probably be fine. If the ram isnt stable a spec above 200mhz, 240mhz on the ht will make the ram exactly 200mhz. Hope this helps.
yeah, we figured that out so we got it it up 2.25 at stock voltage but it got too late and we didnt wanna see what the ram could do, so we turned it back down to 2.16, 240fsb on the proc and just ran the ram at stock. 12 hours prime and still goin
You can do 250 HTT easy with the 166 divider. The memory will be at 208MHz, which really affects it none.
