We just got the NC6320 HP Laptop as a replacement for our NC6120 HP Laptop and it of course has a SATA drive in it. WELL I'm not having a lot of luck thus far.
I was able to update my BartPE boot disk by adding some things to the txtsetup.sif file based on this afticle:
http://www.mail-archive.com/[email protected]/msg00288.html
So then I can use my standard image to ghost the laptop, but when I try to boot it up, of course the SATA drivers aren't in that image so it doesn't want to boot up properly to XP.
SO I re-imaged the laptop and before booting to it went in with PE and modified the sysprep.inf to try and add the intel SATA device but NO LUCK... I just can't get it to come up IF I HAVE SATA NATIVE SUPPORT ENABLED in the bios (which is the default the laptop ships as).
I'm not even sure if modifying the sysprep.inf is the correct thing to do with these SATA drives or not. Any googe'ing I attempt to do don't talk a lot about working with sysprep.
(Mainly just txtsetup.sif and unattended.txt which aren't used with sysprep)
If I shut off SATA Native support my image works and what not but I want it to work out of the box if possible!!!
My image is a sysprepped beauty that works on ANY IDE systems (desktop or laptop) out there and even an HP DC5100 which is SATA but the built in drivers from XP work on it so go figure.
(djnes, this thread started out as PM to you, but I changed my mind, so get your butt outta genmay and look at my thread!)
