Can't get work
dh27
I keep getting and error "couldn't send http request to server.
I've tried turning off all antivirus and firewall to no avail.
Any ideas?
Can you please post hardware specs and your Fahlog.txt file, if we have that we can give better help
--- Opening Log file [September 3 20:24:36 UTC]
# Windows CPU Console Edition #################################################
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\Fold4
Executable: C:\Fold4\Folding@home-Win32-x86.exe
Arguments: -config
[20:24:36] - Ask before connecting: No
[20:24:36] - User name: dh27 (Team 33)
[20:24:36] - User ID: 1D2F30D1490E546A
[20:24:36] - Machine ID: 1
[20:24:36]
[20:24:36] Configuring Folding@Home...
The program will continue in non-service mode now, working in C:\Fold4.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
[20:29:14] - Ask before connecting: No
[20:29:14] - User name: dh27 (Team 33)
[20:29:14] - User ID: 1D2F30D1490E546A
[20:29:14] - Machine ID: 16
[20:29:14]
[20:29:14] Loaded queue successfully.
[20:29:14] - Preparing to get new work unit...
[20:29:14] + Attempting to get work packet
[20:29:14] - Connecting to assignment server
[20:29:35] - Couldn't send HTTP request to server
[20:29:35] + Could not connect to Assignment Server
[20:29:35] + No appropriate work server was available; will try again in a bit.
[20:29:35] + Couldn't get work instructions.
[20:29:35] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[20:29:48] + Attempting to get work packet
[20:29:48] - Connecting to assignment server
[20:30:09] - Couldn't send HTTP request to server
[20:30:09] + Could not connect to Assignment Server
[20:30:09] + No appropriate work server was available; will try again in a bit.
[20:30:09] + Couldn't get work instructions.
[20:30:09] - Attempt #2 to get work failed, and no other work to do.
[20:30:21] + Attempting to get work packet
[20:30:21] - Connecting to assignment server
[20:30:41] - Couldn't send HTTP request to server
[20:30:41] + Could not connect to Assignment Server
[20:30:42] + No appropriate work server was available; will try again in a bit.
[20:30:42] + Couldn't get work instructions.
[20:30:42] - Attempt #3 to get work failed, and no other work to do.
[20:31:05] + Attempting to get work packet
[20:31:05] - Connecting to assignment server
[20:31:26] - Couldn't send HTTP request to server
[20:31:26] + Could not connect to Assignment Server
[20:31:26] + No appropriate work server was available; will try again in a bit.
[20:31:26] + Couldn't get work instructions.
[20:31:26] - Attempt #4 to get work failed, and no other work to do.
[20:32:08] + Attempting to get work packet
[20:32:08] - Connecting to assignment server
[20:32:29] - Couldn't send HTTP request to server
[20:32:29] + Could not connect to Assignment Server
[20:32:30] + No appropriate work server was available; will try again in a bit.
[20:32:30] + Couldn't get work instructions.
[20:32:30] - Attempt #5 to get work failed, and no other work to do.
[20:34:00] + Attempting to get work packet
[20:34:00] - Connecting to assignment server
[20:34:21] - Couldn't send HTTP request to server
[20:34:21] + Could not connect to Assignment Server
[20:34:22] + No appropriate work server was available; will try again in a bit.
[20:34:22] + Couldn't get work instructions.
[20:34:22] - Attempt #6 to get work failed, and no other work to do.
[20:37:06] + Attempting to get work packet
[20:37:06] - Connecting to assignment server
[20:37:27] - Couldn't send HTTP request to server
[20:37:27] + Could not connect to Assignment Server
[20:37:27] + No appropriate work server was available; will try again in a bit.
[20:37:27] + Couldn't get work instructions.
[20:37:27] - Attempt #7 to get work failed, and no other work to do.
[20:42:56] + Attempting to get work packet
[20:42:56] - Connecting to assignment server
[20:43:17] - Couldn't send HTTP request to server
[20:43:17] + Could not connect to Assignment Server
[20:43:17] + No appropriate work server was available; will try again in a bit.
[20:43:17] + Couldn't get work instructions.
[20:43:17] - Attempt #8 to get work failed, and no other work to do.
[20:54:06] + Attempting to get work packet
[20:54:06] - Connecting to assignment server
[20:54:27] - Couldn't send HTTP request to server
[20:54:27] + Could not connect to Assignment Server
[20:54:27] + No appropriate work server was available; will try again in a bit.
[20:54:27] + Couldn't get work instructions.
[20:54:27] - Attempt #9 to get work failed, and no other work to do.
Dont see how hardware will help.
Gigabyte GA-P35_DS3P
Quad Core Q9550
4G Corsair XMS 1066, limited by XP
Please add -verboisty 9 to the command line so we can get more logfile detail and post the logfile again. Restart before posting of course.
Quad Core Q9550
Having your hardware listed helps if other have had similar issues in the past with similar hardware.;)
Arguments: -forceasm -local -verbosity 9
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[21:44:40] - Ask before connecting: No
[21:44:40] - User name: dh27 (Team 33)
[21:44:40] - User ID: 1D2F30D1490E546A
[21:44:40] - Machine ID: 16
[21:44:40]
[21:44:40] Loaded queue successfully.
[21:44:40] - Preparing to get new work unit...
[21:44:40] - Autosending finished units... [September 3 21:44:40 UTC]
[21:44:40] Trying to send all finished work units
[21:44:40] + No unsent completed units remaining.
[21:44:40] - Autosend completed
[21:44:40] + Attempting to get work packet
[21:44:40] - Will indicate memory of 900 MB
[21:44:40] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[21:44:40] - Connecting to assignment server
[21:44:40] Connecting to http://assign.stanford.edu:8080/
[21:45:01] - Couldn't send HTTP request to server
[21:45:01] + Could not connect to Assignment Server
[21:45:01] Connecting to http://assign2.stanford.edu:80/
[21:45:02] Posted data.
[21:45:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[21:45:02] + Couldn't get work instructions.
[21:45:02] - Attempt #1 to get work failed, and no other work to do.
[21:45:10] + Attempting to get work packet
[21:45:10] - Will indicate memory of 900 MB
[21:45:10] - Connecting to assignment server
[21:45:10] Connecting to http://assign.stanford.edu:8080/
[21:45:31] - Couldn't send HTTP request to server
[21:45:31] + Could not connect to Assignment Server
[21:45:31] Connecting to http://assign2.stanford.edu:80/
[21:45:32] Posted data.
[21:45:32] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[21:45:32] + Couldn't get work instructions.
[21:45:32] - Attempt #2 to get work failed, and no other work to do.
[21:45:50] + Attempting to get work packet
[21:45:50] - Will indicate memory of 900 MB
[21:45:50] - Connecting to assignment server
[21:45:50] Connecting to http://assign.stanford.edu:8080/
