I currently use a D-Link wired router to connect to the internet with my RoadRunner cable modem, but recently bought a laptop with WiFi and thought I should upgrade to a wireless network. I have tried 3 WiFi routers and all 3 don't work.
First I got the Linksys WRT54G. When I plugged the cable modem into the router, the cable modem's PC LED wouldn't light up.
Second, I got the Netgear WGR614. When connected the PC light on the cable modem would blink sporadically instead of staying solid so the internet would be on and off and in general annoying.
Third I got the D-Link DI-524. When I connected the router and cable modem, the PC LED would only light up right when the router is plugged in. It would blink a few times with the WAN LED on the router, then both would stay off.
However, if I have the wireless router connected to my wired router the WiFi would work fine.
Also, the cable modem's PC LED doesn't seem to come on when I connected directly to the PC either.
