Its an updated problem now, sound works, but headphones still dont heres the update from a month ago:
Well its been a month, and it still has a problem, i was working on it today, and got some improvement, on the left earbud of my headphones, you can actually hear the faintest sound of the music playing, but its SUPER faint, and its only in the left headphone, heres my ALSA base right now :
Code:# autoloader aliases install sound-slot-0 /sbin/modprobe snd-card-0 install sound-slot-1 /sbin/modprobe snd-card-1 install sound-slot-2 /sbin/modprobe snd-card-2 install sound-slot-3 /sbin/modprobe snd-card-3 install sound-slot-4 /sbin/modprobe snd-card-4 install sound-slot-5 /sbin/modprobe snd-card-5 install sound-slot-6 /sbin/modprobe snd-card-6 install sound-slot-7 /sbin/modprobe snd-card-7 # Cause optional modules to be loaded above generic modules install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; : ; } install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe -Qb snd-seq ; } install snd-pcm /sbin/modprobe --ignore-install snd-pcm && { /sbin/modprobe --quiet snd-pcm-oss ; : ; } install snd-mixer /sbin/modprobe --ignore-install snd-mixer && { /sbin/modprobe --quiet snd-mixer-oss ; : ; } install snd-seq /sbin/modprobe --ignore-install snd-seq && { /sbin/modprobe --quiet snd-seq-midi ; /sbin/modprobe --quiet snd-seq-oss ; : ; } install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; } # Cause optional modules to be loaded above sound card driver modules install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe -Qb snd-emu10k1-synth ; } install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe -Qb snd-seq ; } # Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway) install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe -Qb saa7134-alsa ; : ; } # Load snd-seq for devices that don't have hardware midi; # Ubuntu #26283, #43682, #56005; works around Ubuntu #34831 for # non-Creative Labs PCI hardware install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe -Qb snd-seq ; } # Prevent abnormal drivers from grabbing index 0 options bt87x index=-2 options cx88_alsa index=-2 options saa7134-alsa index=-2 options snd-atiixp-modem index=-2 options snd-intel8x0m index=-2 options snd-via82xx-modem index=-2 options snd-usb-audio index=-2 options snd-usb-usx2y index=-2 options snd-usb-caiaq index=-2 # Ubuntu #62691, enable MPU for snd-cmipci options snd-cmipci mpu_port=0x330 fm_port=0x388 # Keep snd-pcsp from beeing loaded as first soundcard options snd-pcsp index=-2 options snd-hda-intel model=3stack enable=yes options snd-hda-intel model=auto position_fix=1 enable=yes options snd-hda-intel model=lenovo
And the /sbin/lsmod | grep snd
Code:snd_hda_intel 384176 3 snd_pcm_oss 46848 0 snd_mixer_oss 22784 2 snd_pcm_oss snd_pcm 83204 2 snd_hda_intel,snd_pcm_oss snd_seq_dummy 10884 0 snd_seq_oss 38528 0 snd_seq_midi 14336 0 snd_rawmidi 29824 1 snd_seq_midi snd_seq_midi_event 15232 2 snd_seq_oss,snd_seq_midi snd_seq 57776 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event snd_timer 29960 2 snd_pcm,snd_seq snd_seq_device 15116 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq snd 63268 13 snd_hda_intel,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device soundcore 15328 2 snd snd_page_alloc 16136 2 snd_hda_intel,snd_pcm
I could really use some help, and im open to any suggestion.
And heres a screenie of my soundcontrol panel just in case...
