I just got my spare machine up :
MOBO gigabyte GA 945g-zm-s2 rev 3.0
D-820 CPU
1gig Dual channel ddr2 533 2 sticks 512
wd SATA 3.0 320 HD
Nec DVD bURNER
Winxp pro sp2
It has the ich7 chipset which I thought was SATA 3.0
I went to intel got the floppy install, did the F6 when installing used the ich7 ahci driver.
It installed windows XP Pro fine.Under device manager it shows the correct SATA controller ,but under primary ide it is listed as udma 5. I have the bios on Auto for configuration of SATA, I have tried every bios setting enhance, combined. non combined and even turning off PATA. How do I get SATA 3.0 to work? I even tried the intel storage matrix software it wouldn't install. Help!
D-820 CPU
wd SATA 3.0 320 HD
Nec DVD bURNER
Winxp pro sp2
