Cant get past 3.150, e6600 P5B
UberPooner
Ok, so i think i have a problem and ive spent a while trying to fix this by researching and trying different things and NOTHING works. so i have decided to ask you guys. this is my problem.
I Get pretty good performance when i have these settings: fsb 350x9 ram 1050mhz.with that i get a score of 7200 on 3DMark06. and im getting about an average of 40-55 fps. and on css stress test i get like 270fps.
Now i figure if i up the fsb i should get better performance, well in my case that is the opposite of what happens. Like i tried setting the fsb at 400x9 to give me 3.6 and the ram at 1000(and i tried 800) and everything looks fine, heat is like maxed at 60c and i ran orthos for about 3 hours and no errors.
But when i go to Benchmark in 3dmark my average fps is like 5-10 Wtf so i didnt even finish with the benchmark. also in css im getting like 210fps. ive tried different combos to and get same results like fsb of 425x8 same problem 400x8 same problem
So is there a way to fix this or am i just going to have to stay stuck at 3.150ghz?
Oh and i also tried setting the pci sync mode to auto and 33.33, didnt do anything.
specs are in sig.
I don't know if the CPU is throttling perhaps, but there were talks about the selected FSB and the performance hit it brings due to some internal dividers for the memory. The conclusion was to avoid FSB from 401-470 FSB or about so, but the 400 MHz FSB was deemed as OK.
The other issue you might try is to check if your PCI-E throughoutput has dropped to x1. It happens sometimes when overclocking this motherboard and the solution was to set the PCI-E bus to 96 MHz or so.
Check this thread for some issues and proposed solutions:
http://www.short-media.com/forum/showthread.php?t=50712
your 3dmark06 score is very low if that is with e6600 @3.1 and 8800gtx.
i got a e6400@3.0 and 8800gtx stock and my score is around 10,700.
Hay, i ran it again with no aa (the other was at 8x aa) and i got 10469, but yours is still better lol.
Try to do a 3Dmark test at 390FSB and see if your scores improve any, and post back here.
It might not be stable.
if you ran it and you got within 10k range, then your okay. how are the fps in the games you are playing. when i play fear i get in the 110average. that is with everything max @ 1280 by 1024.
That would not be a good idea as the P5B-E has a hole around 366-399 where the strap is severely overclocked making it very instable in that range. You are better off above or below that hole or else you will have trouble even booting.
That score does seem a bit low as my rig in my sig (e6400 @ 2.8 w/7900GS) gets almost 5000 in 3dmark06
specs are in sig.
You should not be running your memory at 1050mhz. That is insanely high. It means your memory multiplier is 3 when it should be 2 In other words your memory should be running at 2x350=700. Instead it is running at 3x350=1050. That is not good. You are running the memory way too fast.
I am not an Asus owner so I don't know how to set it in your motherboard but that is what you have to do, manually set the memory multiplier to 2.
Once you get that problem taken care of, when you set your FSB clock to 400 the memory will be running at 800 which is the rated speed, and by that time your CPU will be at 3600 MHz. I am not saying whether or not your CPU can run at 3600, just that the memory will not be overclocked at al at 400 FSB.
