cant get past 204 FSB!!!
Ph0s5ph0L1p1D
OK im running an AMD 64 4000+ on asus A8v with 1GB corsair 3200XLPRO in dual channel. I got the latencys to 2-2-2-5 but I get errors in prime95 if I put my FSB over 204. WHat can I do? what should I do? the volts dont really seem to make a difference so Im sort of in a jam.
O yeah Im running an Ultra X-Connect 500W PSU and my temps are 37C idle and 41C full load.
looosen your timings. 2-2-2-5 on TCCD doesn't run at high fsb. Try 2.5-3-3-7 or 3-4-4-8.
Despite all the hype
an a64 will also benefit from a higher FSB vs lower timings (to a degree of course)
Make sure your chipset has adequate cooling. I hit a 208 FSB wall on my NF7-S with watercooling on CPU and GPU. Looser memory timings and lower CPU multiplier and higher voltages did not help. Once I swapped out the stock chipset cooler with a Thermalright NB-1C, I was able to hit 215.
yea it worked, so far Ive got up to 210FSB and still going. Thansk for your help guys. really appreciate it.
