Cant Get Onboard Working, help please!
Bleedblue12345
hello
i cant get my onboard grahics to work. i want to switch my 7900gs to a different computer, but when i take my 7900gs out and plug into my onboard using vga (i use dvi on my 7900gs) the sysem wont boot up. It wont even beep. Anyone have any suggestions. PS. my onboard is nvidia 6150 so drivers shouldnt effect it.
There usually is a setting in the BIOS to switch between onboard and deligated GPU's.
Correct, check the bios to make sure there is shared graphics memory enabled (64 or 128 MB) and onboard VGA or onboard graphics are set as enabled and/or set for init display first.
So you see, you boot your computer with the pci express card, go into the bios, make those settings changes, and then try plugging the monitor into the onboard video again.
