Cant get mobo to detect harddrive help!
chinese
I have a an MSI PT880 NEO-LSR motherboard and I can't get it to detect my WD 36GB Raptor hdd. Can anyone help?! In the boot sequence menu under bios it shows up as BBS-0(RAID0):WDC 360GD-00FN but it won't load windows, and if I try to reformat it says no harddrive detected. Am I missing something here? Maybe I plugged the cables in wrong--I have the ATA cord, ATA Power cord, and Legacy Power cord plugged in, I've tried using only the ATA + ATA Power cords and ATA + Legacy Power cords but they still don't work. I remember when I used the harddrive on a shuttle setup, I had enable some Enhanced IDE devices or somethign to that extent in bios, but I can't find it in this MSI one. HEEEEEEEEELP!!!!
You've set up bios properly, but did you check the jumper on the hard drive?? Make sure the jumper on the hard drive is set to "MASTER" and not "SLAVE". If the drive is set to slave, Windows will not recognize it as "HDD-0". Bios should be set to boot in the following order when doing a clean install with XP....First Boot Device--CDROM, Second Boot Device--HDD-0. If the jumper is set to "SLAVE", the motherboard is seeing the drive as HDD-1. If that don't help, you might have to RMA the MOBO.
