Can't get FSB over 216mhz?!
Silen7
I'm pretty sure that 216mhz is a ridiculously low FSB overclock value. This is what i did: First i set my HT multi to 3x, then i set my cpu multi to 5x, then i set my ram freq to 100mhz (ddr200 speed). As i gradually overclocked my FSB i could only get to 216mhz before my computer rebooted. My temps were fine (below 35). I have an fx-55, asus a8n sli premium, 4x512mb corsair twinx3200-512xlpro. I'm trying to find the maximum FSB my mobo can do, and from what i hear, i should get it to be way over 250. What am i doing wrong? :confused: :confused: :confused:
Did you lock your PCI and PCIe busses at 33 and 100mhz (respectively?)
Disable spread spectrum?
try set your multi higher to like 8 or 9.
I have essentially the same board, an Asus A8N SLI Deluxe, and am running it at 280 with no problems. The only thing I can think of is to try with only 2 sticks of ram. I have heard that running 4 sticks of ram can limit overclocking. Apparently you need to run 2t ram timings with 4 sticks of ram inserted.
Bingo, I'll bet that is your issue. The built in mem controller hates 4 sticks of mem
bump the voltage up on the cpu and ram ,
losen up the timings a little ,
i have the same motherboard (Deluxe Edition), i couln't believe asus would put out such a garbage this motherboard is, (this board reassured me that asus is not as good as everyone says it is, dfi mobos are way better)
it was total crap with its latest stock bios (the motherbord havent had a bios update in like a year, even tho its still selling and has shit load of problems), i had to flash it with the 1302 premium bios just to get it stable ,
It most definately your ram, the on die mem controller hates 4 sticks... and will kill your FSB overclock by 75%. It also makes it that you have to run 2T instead of 1T, that also kills your FSB OC.
Its a well documented fact that on AMD's, 4 sticks of ram kills the OC.
Hey guys,
Ok, after reviewing everyone's responses (thanks again) i tried a few more tests. The first thing i tried was setting the PCI bus to 33.33mhz and trying again. That time i got a FSB of 220mhz before a BSOD occurred. Then i tried loosening the timings to 3-3-3-6 2T and upping the cpu multi to 9x. That time prime gave me an error at 215mhz, followed by a system reboot. I'm still not sure what im doing wrong. Could the problem really be that im using 4 sticks of memory? I just recently got another two sticks to get 2gb because i didn't feel like spending $200+ on a dual channel kit. BTW, my mem voltage is at 2.75, and my vcore is 1.4. Thanks in advance.
Sorry bradyapba, i was in the middle of posting when you replied. i loosened the timings, and kept the command rate at 2T, shouldn't that help at all?
Definately your ram... take out those 2 sticks... its all about the mem die controller, and how it has to controller the 4 sticks vs 2.
Heres a great article that explains the problem.
heres a snipet
"Using the same DIMMs and same timings, we could only reach a 240 Processor Clock or +20% with 4 DIMMs. Two DIMMs allowed an overclock to 318 or +59%. With two DIMMs, we could overclock almost 3 times higher than with 4 DIMMs. You can likely overclock a bit higher with 4 DIMMs by further tweaking memory timings, but 4 DIMM overclocking will always fall far short of 2 DIMMs on current Athlon 64 memory controllers"
link
Yes, it is the 4 sticks. Same issue on my DFI. It blows. If I play games that require a lot of mem I will lower my clock and put in 2 more sticks. Usually 2 sticks does the trick just fine, though.
Silen7 said:
Hey guys,
So what happens when using only 2 sticks RAM??
