Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I can't get the Amazon Tap configured.
Does anyone know what ports Amazon tap (and ipad with app) needs to get a tap configured?
It doesn't appear that my tap makes it to pulling an IP address.
So, I finally figured out what caused the problem. I do not broadcast my SSID on my Wifi. Turning it on (temporarily) fixed it.
This is strange as the Alexa app allows to add a not discovered Wifi network.
However, the experience is still not great. The Alexa app on the ipad is super slow. Sometimes I don't get to setup screens. The Alexa app does have very bad reviews on the app store. Amazon Alexa on the App Store
But I don't think there is an alternative? At least not for setup?
