Can't Get 2.5 CAS With TCCD
shimq1
I have the OCZ Platinum Rev. 2 1GB (2x512MB). It seems that whatever settings I use, CAS 2.5 is never 3D stable. I'm only running them at 260MHz and 2.7V. What timings can I loosen other than the CAS?
The other ones are pretty loose... try going to cas3. If that doesnt work, raise voltage a bit, some TCCD loved voltage, others not so much. If its not giving any gains, back off.
My TCCD sticks topped out around 275, 2.5-3-3-5. They didnt really like higher timings, you might just have a pair of weak sticks...
I had this with PQI Turbo memory that would do CAS2 and CAS3 but no CSA2.5. CAS2 was only stable setting available.Think running them at 3.2v in DFI NF3 for 2.5 @ 320MHz killed it off
Odd, my PQI Turbo TCCD works fine at 2.5...
Oh it did used to great (320MHz 2.5-4-3-7 3.2v) but after a lengthy stint at that it didn't!
