Guitarrasdeamor
- Apr 5, 2008
http://www.amazon.com/TRENDnet-TEW-423PI-54Mbps-Wireless-Adapter/dp/B0001DHHIY
I am using this wireless adapter (this is a desktop), and I cannot get it to connect. I just re-installed Vista, and tried to connect it, and it wouldn't with the password or anything. it just freaking won't work. I have tried everything. I have manually reset the router and modem, removed all passwords, set it to DHCP fully (I THINK!!!), done freaking everything.
I am using XP with the wired connection right now. I don't know how to freaking connect, and my other PC is connecting with a wireless connection (Linksys USB adapter), and I don't know how.
Using a WRT54GS v.4
EVERYTHING WAS FINE BEFORE I RE-INSTALLED VISTA.
Using a WRT54GS v.4
