Cant format...why
overstand
Drive D: and F: are the same HD. Everytime I try and format D: it won't let me, how do I format the d: drive and the other one, as well as make it one partition.
Ok, I formated f:, but now I cant even do anything in does becuase it says the comand im typing is not recognized as an internal or external comand,operable comand or batch file.
And this is typing any comand, how do i fix this?
you should type format C: \q\s \q=quick format \s=copy system files (command.com)
what exactly are you trying to do now? boot to cd to load windows?
At this point, back up and start over. Might want to call a friend in who knows about drive formatting.
this board is mny best help.
Now its saying when i try to format D: , it's saying that this file system is RAW. Please type /FS switch to specify the file system you wish to use on this volume
get MaxBlast or similar drive prep software from the maker of your hard drive. It should be foolproof.;)
