I just installed the 6.5s, but I cannot find the CCC. My previous drivers (5.12) did not have the CCC either, I would click on the shortcut and it wouldn't find it and show the flashlight. But since I did a clean uninstall of the 5.12 and just installed the 6.5s, should't it show up again? (i should note that during driver cleaner there were a couple of errors when cleaning the CCC, but it finished running anyway, something about (Internal error 2753. altishlx.ece and error 1316,a network error occured while attempting to read C:\Windows\installerATI Catalyst Control Center.msi)when I tried to remove CCC in the add/remove programs menu, 2 CCCs remain, but I can't remove them) I also disabled a bunch of stuff on msconfig but I went back and put a checkmark on ATI Catalyst sys... (can't read the rest) and I had all my shortcuts deleted when i did driver pro, so there is no shortcut in the desktop anymore where I can click to see if I have it now. Should either of these 2 be checked under 'Services' in msconfig: Ati Smart, Ati hotkey poller. I also found my 6.12 install folder and inside i opened the ACE.ece to repair/install CCC, and restarted but I don't see anything. Thanks I just want to be able to turn on AF again, it's been months since I haven't been able to use CCC. Sorry if it is not very clearn, this is confusing to me.
Edit: to make it short, I would just like to properly uninstall the last 2 version of CCC which still show up in add/remove programs, but are not currently working, and install the new CCC that came with 6.5. Thanks
