onetwenty8k
- Nov 24, 2006
I've googled this up the wazoo and all I can find are smart ass forum nerds saying "search" but low and behold, I can't find anything helpful except "forward your ports" which I have done.
I can't seem to find any MW2 matches except for hacked servers which connected after everything else failed searching through pings of servers. I am not at level 70 where I can prestige, I'm just level 22. The weird thing is that it had worked before but now it just won't do it.
My network setup:
FiOS internet which connects to an Actiontec mi424wr rev d. That router is set up as a bridge to my D-Link DIR-655. I have my Actiontec router (internal IP of 168.192.0.100). The subnet for the actiontec is 192.168.1.x and the D-Link is 192.168.0.x
The actiontec router is set up in the DMZ of the D-Link and for years that has worked which allows me to control ports on the D-Link side but now it simply won't work. I can connect to IWNet fine but it just doesn't find any games. There is obviously some port problem but for the life of me I can't figure it out. I have forwarded ports on both the actiontec and D-Link and they still show closed. I have turned off my windows firewall and checked again to see that they are closed. Any suggestions? Thanks.
My network setup:
