Can't find mobo features I need.
Carlosinfl
Loves the juice
Guys,
I am not sure if this is available but maybe you can tell me.
Board that supports the old P4 3.02 GHz CPU
Built in WiFi
4 or 2 port S-ATA
Dual Gigabit Lan
AGP and PCI Express
I really doubt such a board exists. The PCI-E boards are the newer chipsets which take socket 775. Also putting AGP and PCI-E on a board would not be practical as you would need two different chipsets. Someone correct me if I am wrong.
It's possible to have both PCIe and AGP in the same chipset, and at least two chipset manufacturers were working on a solution, but it's not easy to get both working properly at the same time, and as most people will not even make use of AGP and PCIe at the same time (except perhaps during a short upgrade period), the incentive isn't really there either.
There was one mainboard manufacturer (Gigabyte?) which used an AGP/PCIe-bridge solution to add an AGP slot, but this was basically a hack, and might shorten the lifespan of any AGP card used.
