Can't find culprit of 100% CPU on AP1142N
4GSam
My CIsco LAP 1142N running in autonomous mode is reporting constant 100% CPU usage. It seems to work fine, though the other night I got home and it wouldn't let anything connect to its SSID (reboot fixed it)
Here is a log of what's running:
https://dl.dropboxusercontent.com/u/121069/Public Images/comcast/cisco-output.txt
This is my first time using a Cisco AP. I upgraded the firmware to the latest release and it's still at 100%. Any ideas?
Offhand I can't see anything there using virtually any CPU. Is this by chance hooked up to a switch with other VLANs on it that aren't being pruned from the AP's port? Or is there a loopback interface configured on the AP?
What does "show log" show?
No loopback. It's running off an older 2950 switch. I only have two VLANs on the whole network, one of which is VLAN 1.
Does PoE make a difference? It's running off a TP-Link 802.3af adapter
This is pretty much all the event log shows.
Code:
cisco-ap>show evtlog 10
Current evtlog contents:
Sep 6 11:59:21.051: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:01:21.063: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:02:21.065: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:12:23.987: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:14:21.129: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:16:21.134: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:22:23.424: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:22:33.987: %DOT11-4-MAXRETRIES: Packet to client 0022.4c00.d782 reached max retries, removing the client
Sep 6 12:27:21.183: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
Sep 6 12:32:21.206: %EVT-4-WRN: d0: Prevented attempt to enable beacons by non-driver process pid(57)
*** End of last 10 lines from evtlog ***
cisco-ap>
