Can't find a case for this MB...
Maliki2
Friend got a PCchips M925ALU MB.....but I'm having a hard time finding a CHEAP (yes need it VERY cheap) case for this thing. Its MICROATX...but the configuration of the back IO ports etc, are different then the norm. Anyone have a idea where I can find a decent case that will work with this MB? The MB came with the template for the ports but alot of cases are riveted in a configuration already. All three MicoATX cases I have won't line up with these ports.
Mb linke is .... http://www.pcchipsusa.com/prod-m925aluv71.asp
Yup it did come with the plate as I stated above. Problem is all the cases I've gotten so far have a place already pretty much installed already that don't match the current configuration of the board. So I would have to hacksaw or cut pieces out.
:confused: the backplates of ATX cases are removeable ... you just pop it out ....
Just wack out the plate with the back of a good sized screw driver. You will be all set.
