late last week i got my PSOne car adaptor for use on my LCD screen. So i cut off the cig lighter end and figured out which one was ground and wich was power and hooked it up to a molex on a PSU i use for a low end duron system. It worked fine, so i let it be. Anyways now that Im nearing teh end of my mod, I went in to hook up the switch for the adaptor, so I leave the ground to flow thru freely, and put the switch on the 12v line going into the transformer, turn on the system, measure with a MM while the swithc is off, no current so its perfect. Turn the switch on and the PSU cuts out. Im assuming theres a short somewhere but I cant seem to find it. I tried testing it the way i did when i got the adaptor and it still gave me problems so i went away for ~ 1hour and came back, tested it the way i did when i got it, and it worked. So i hook up the switch again, and it doesnt work. So now its a day later and i cant get it to work at all
pls help me
Sean
pls help me
Sean
