Animositisomina
- Jan 11, 2011
[Since I didn't mention this until later in my post, here is what card I have: PowerColor Radeon HD 6970 2GB.]
I just got done uninstalling my old GPU today and installing a new one, but I'm running into some problems. I had an nVidia GPU previously, so I made sure to completely uninstall the old drivers and nVidia-related software first. I then physically removed the old card and put in the new one. Both power connectors are plugged in tightly, the card is seated well into the PCIe slot, and no cables are touching the fans, etc.
Here's the problem: When I boot up, after a few seconds my monitor turns black, the GPU's fans go full-speed, and I get a message saying "No Signal Input, Check Video Cable". I have checked the cable in the back of the computer, it is plugged in as snugly as possible, both screws are in place tightly as well.
I was able to get to my desktop once, briefly, and Windows started doing that automatic driver install process. Shortly after though, it went black as described before.
Any idea what's going on? Could it be that my PSU is not powerful enough for this card? I have a 650w PSU and the card requires a minimum of 550w. Have I just not installed the card correctly? It's a Radeon HD 6970, by the way. It has two places I can plug my monitor into. When I use the upper spot, I get the problem described above. If I use the lower spot, the screen remains black the entire time and I don't even see the boot screen.
Any help at all would be greatly appreciated.
