cant figure it out....
antok86
what can i do so my comp isnt so hot. the temps are cpu 32C and HD 34 and Video idles around 52c. i have the intake fan 120mm w/filter and a 80mm exhaust. and it seems to keep my room really warm even with the A/c on. this is even the case b4 i moved to a new house. i dont know whats going on. any idea that will help me have a cooler case/room? maybe its the filter?..i duno
lets leave the smart shiz for later....its getting hot...
thanks
those temps are pretty good....your room is warm because that heat has to go somewhere. A heatsink doesn't take the heat and turn it into cool fresh meadow scented air.
if you want to drop the vid card temps get a zalman cooler or something of the like.. but your cpu temps are normal
temps look good to me....
but if you want your rig to put out less heat try underclocking/undervolting it for starters
airwick should make computer cooling solutions. 2 birds with 1 stone! then everyone's computers will have the exhaust on the front.
