Can't extend desktop...
therealdrag0
I have an Alienware Aurora m9700 with SLI NVIDIA GeForce Go 9700 GS graphics cards. I got a Hanns G HW191A monitor and I'd like to extend my desktop onto it. But I have been unable to.
When I click the "Extend my Windows desktop onto this monitor" boolean box under Display Properties > Settings, it then makes the two preview rectangles black (instead of one grayed out). But then when I click apply, my laptop screen goes black for a second and then comes back on as if nothing happened. Nothing else is changed, and the "Extend..." box is now unchecked.. :(
Thoughts?
Thanks.
I've never worked on a laptop where I could extend the screen onto an external monitor.
I've never worked with one where I couldn't. Usually it's the laptop display as one monitor, and the port in the docking station as the other. If you've got two ports on the laptop, I would definitely see if it's compatible. If it is, try updating the video drivers...
Yeah. It works fine on my 10" MSI Wind laptop. But I can't update the drivers on my Alienware because it's a from Alienware and no further ones are compatible.
Woop I figured it out. I went and got the drivers and installed them. And as they installed a bubble popped up saying essentially, "SLI now enabled, one of your screens may have gone black." And then the metaphorical light bulb went on. So after I disabled SLI it works.
